Old 05-11-2019   #1
Australia
Heater coolant connection
From the X1/9 heater there are 2 hose connections, one from the control valve.
Emerging from the prop tunnel are 2 pipes, these pipes connect to the heater.
Question. The pipe closest to the firewall - does this connect to the heater valve.
Thank you
Piddo
Piddo is offline Reply With Quote Quote
Old 06-11-2019   #2
Iggy64 has donated!
Re: Heater coolant connection
From memory, I think that's right but on my car the heater valve is clearly visible in the driver's side footwell above the clutch pedal. Should be easy to see which pipes connect to it.
Iggy64 is offline Reply With Quote Quote
Old 07-11-2019   #3
Australia
Thanks for the information, small problem, this has been a 7 year project involving the complete replacement of the cooling system 'plumbing'. Currently, I have the heater back in position with 2 new metal pipes and no memory as to the hose positioning. The question is to identify the hose that goes between the heater valve and the correct metal pipe, from your comments, it appears the heater valve connects to the pipe closest to the bulkhead. If I have misread your advice, please correct me.
Thank you
Piddo
Old 08-11-2019   #4
Iggy64 has donated!
I'm pretty certain that's correct. Have a look at a previous thread (2010) under X1/9 Heater Valve Replacement. This has some photos showing the valve and pipes. Although this is a lhd car, I think the basic layout is the same and the pipe with the valve is definitely the one closest to the bulkhead.
(T) Heater motor loose connection welshy0007 Grande Punto 1 11-09-2016 13:29
(G) Immobiliser LED connection near heater fan. Zog Scudo 0 17-09-2015 16:14
(T) Heater blower electrical connection Jaquesschitt Cinquecento / Seicento 6 06-12-2014 13:38
(T) Lose Connection Coolant Temp. Sensor Failure stiatfilo Stilo 4 09-04-2011 09:27
(T) Seicento coolant sender connection at dashboard jimp Cinquecento / Seicento 4 25-07-2008 06:35
