Old 08-03-2013   #1
South Africa
Question Nose Cone Replacement
Hello all - My Fiat X1/9 "Clara" needs a new nose-cone (the section between the headlights) Are these easily removable or is this a bodyshop job?
DaveHolmes is offline Reply With Quote Quote
Old 08-03-2013   #2
Re: Nose Cone Replacement
Hi Dave
With a bit on drilling,grinding and welding should not be to bad to do,if you have a spot welder that would make life a lot easier.
http://www.ebay.co.uk/itm/Fiat-X1-9-...item1c30ad0229
The pictures show that you can spot weld along the front and along the back and sides you can drill and plug weld
If you take the bonnet, headlights and bumper off you will see the spot welds you need to drill or grind out
Shaun
shaun is offline Reply With Quote Quote
Old 09-03-2013   #3
South Africa
Smile Re: Nose Cone Replacement
Shaun, I am very grateful for your reply. Since postage is so expensive these days, and because the part is of a significant size, I think I will try to find a 'breaker' here in South Africa. I don't have a spot welder, but would ask a panel beater to do that for me, or even consider bonding after painting. You've given me the courage to go ahead at least! Best regards, Dave
Old 09-03-2013   #4
Thumbs up Re: Nose Cone Replacement
Good luck Dave
(G) Replacement Air Filter Cone corky Punto (Mk2/2b) 9 04-03-2011 14:36
(G) Nose weight Tiggs Multipla 3 21-11-2008 14:14
(S) New nose or old nose? Uomodell'Italia Barchetta 35 22-09-2007 12:05
