Hi. I am planing to change my top struts mounts all around because they are cracked and also centre of mount looks bit away fom right possition. Also it make a noise when car is going over bumps.
Does somebady knows where I can buy them cheaper then 35 euros/ each?
The second option I am thinking about is to repace the middle rubber with polyurethane. I find there is exist 2 part urethane resin, but with diferent Shore hardness (40,60,80..)
Which one is the best to use to have good mount for road use? I gues 60 will be ok, but I dont want my car to be very stiff and the vibration goes to the body....
I want to remove old rubber from the plate and the questin is how much I can compress the polyurethane, because I have to figure out the moulding properly for it.
Does somebody has experieces with making the poly bushes?
