My reverse gear works 100% however it takes alot of effort to put it in reverse. if you would normally put the shifter into the reverse gear position it will engage in 4th gear.
for it to effectively work you would have to push the shifter extremely hard to the right then push it down into reverse.
what could be the cause of this problem?
