FIAT Auto Specialist Team
Old 19-09-2006   #1
UNO POWER!
fiatunoturbolover has donated!
Exclamation Indicator trouble!!!
Hi, i have a fiat uno 94 IE.
My bright spark of a friend decided to put the + and - together when he was jump staring the car, and blew the left indicator. But now the right one has gone too.
The thing is, all the other indicators work, inc the side ones... but just not the front ones.
I have tried changing fuses/bulbs... but thats not helped... i even tried changing the entire fitting on the left indicator... still no joy. So I am now stuck unable to drive my car due to lack of indicator!
What could be wrong with my indicators, any ideas?
Thanks in advance guys/gals!
fiatunoturbolover is offline Reply With Quote Quote
Old 19-09-2006   #2
UNO POWER!
Re: Indicator trouble!!!
I have just tried the solanoid (spelling?) and thats fine, not burnt/blown at all.
Old 19-09-2006   #3
Mighty v6 power
Rob-mint-mk1-uno's Avatar
Rob-mint-mk1-uno has donated!
Sounds to me like you have blown the relay up. Take it out and replace it for another and see if thats ne good, failing that i'd check your wiring to the indicators at the front and check they are not burned out.
I dont see how you managed to do this by putting the live and earth round the wrong way as bulbs dont have a polarity they can work either way round, does every thing else work ok..
So long F225 HHH you will be missed.......
Rob-mint-mk1-uno is offline Reply With Quote Quote
Old 20-09-2006   #4
UNO POWER!
Well, i dno.... I will have a look. All that happened was, my numb nut of a friend put the positive and negative cables together when jump starting my uno.... which in turn blew the front left indicator. and then only recently 2 more indicators have gone.
Old 20-09-2006   #5
Chas Uno has donated!
Air Dodge Champion, Asteroids2000 Champion, Frogger Champion
I agree with Rob. Sounds like you might have fried part of the indicator relay.
Have you got a volt meter that you can use to check and see if voltage is coming through to the indicators? Checked to make sure none of the wires have burnt/ shorted?
Quote Originally Posted by Trinity View Post
we got a lot 126 here in Egypt .. a funny car and fun to drive though sometimes i feel like I am sitting on a chair in the middle of the street
http://onastick.net/drew/sinistar/
Chas Uno is offline Reply With Quote Quote
Old 20-09-2006   #6
Mighty v6 power
Thumbs up Re: Indicator trouble!!!
Pretty sure u have fried your indicator relay, just try replacing it and then change all your indicator bulbs and try again.
I cant see how shorting the battery out has caused just the indicators to pop,but ill try change the relay and bulbs that should do it..
Old 20-09-2006   #7
UNO POWER!
Well, I got an auto-electrician out through my uncle.. so i knew he wasnt a cowboy.
Turns out it was a major coincidence, and that the indicators were popping off one by one all because of the age of the car, the connections were screwed, and needed replacing. And the funny thing was, just as he fixed the three broken indicators, another one broke . So he fixed that and now all the indicators are sorted. All in all it only cost £30... so a good deal!
again, thanks for the help people!
Old 20-09-2006   #8
Mighty v6 power
Well done my son....
Old 22-09-2006   #9
Trader Rating: 1
alexGS has donated!
New Zealand
Yes - I thought it was a strange one
During vigorous use of the steering, the indicator flasher has sometimes popped out of my Uno Turbo's indicator switch assembly - I take the covers off the steering column and find the flasher lying in the bottom. Of course when this happens, all indicators and the hazard flashers stop working.
Uno lights are definitely in need of TLC at this age: another common problem with the fronts is the earth connections that push on to multi-spade terminals behind the headlights. But if you clean and tighten everything with pliers, they should all work again. Back lights are similarly notorious - the multi-pin plugs often need cleaning/tightening. Even washing the lens makes a difference to the brightness This is all stuff you can do yourself, with assorted screwdrivers, pliers, 'Scotchbrite' (green scourer), and a spraycan of electrical contact cleaner.
You think £30 is a good deal? I can almost hear PeteG sniggering from here... never mind, there's always next time to save your money sorry I didn't reply earlier!
-Alex
'15 Giulietta 1.4MA, 14 Abarth 500C Esseesse, '08 500 Lounge 1.4 Dualogic, '08 G Spyder, '71 850 Coupe in bits...
alexGS is offline Reply With Quote Quote
Old 25-09-2006   #10
UNO POWER!
Yeah I think 30 is pretty good.
All the front/side indicator plugs needed removing and soldering and just as the guy fixed one, another went. I would rather pay 30 for 2 hrs work by a skilled auto electrician, than spend all day without any testing equipment doing it myself.
Plus, all the other quotes I had of auto electricians were 30 just to FIND the fault.
Again, thanks for all the replys people!
