Old 30-06-2019   #1
South Africa
engine runs on after switching off
Hi folks
I have had the Uno Fire motor rebuilt last year, the head rebuilt with new valves last month and a new ignition module this last week.
Prior to the new ignition module being fitted the car would carry on running after switching off, and the only way to stop it quickly is to leave it in gear and let out the clutch.
Now the car has all the power does not over heat but still has the running on after switching off, although not every time. I did two trips yesterday one to the shop - no problem, and then one home again - engine ran on after switching off.
Any assistance would be appreciated.
Kindest regards
Graham Lawrence
grayjen is offline Reply With Quote Quote
Old 03-07-2019   #2
s130 has donated!
Re: engine runs on after switching off
Run on is often associated with a too far advanced ignition timing.
I would check the static timing to begin with. If this is OK then look at the dynamic and vacuum advance.
Not clear from from your post if you have a carb or fuel injection.
s130 is offline Reply With Quote Quote
Old 18-07-2019   #3
Vatican City
Post Re: engine runs on after switching off
In new generations of Fiats (like for example Grande) problems like that are mostly electrical (wiring).
So consider this also (but OK, in older ones it will be more mechanical: bad timing, carbon deposits, etc.).
Last edited by GrandePunto PL; 18-07-2019 at 16:40. Reason: Mechanical and/or Electrical.
GrandePunto PL is offline Reply With Quote Quote
(T) Intermittent Starting, engine switching off, dash lights, and other woes! klop Panda 10 13-05-2016 12:25
(T) How do I have the car stereo go off with switching off the engine? BasHopman Punto (2012+) 2 15-06-2012 21:09
(T) Switching the stereo off with the engine dr6633 Panda 5 16-12-2011 17:06
(T) bravo 1.6 engine petrol engine runs like diesel emre2blue Bravo / Brava 9 15-06-2008 17:07
(G) Switching engine off in neutral Abarth Sellyspeed Pbody123 Stilo 5 13-01-2008 14:27
