Technical Fiat Uno 45 brake reservoir cap
Threapwood
Hey dudes, just bought myself an '89 fiat Uno 45 999cc fire and I love it! Can't believe how clean it is not a spec of rust.
Couple bits need doing, one of which is the bloke I got it off for some reason fitted a different brake master cylinder reservoir cap which isn't from this car and doesn't fit. These ones have a sensor on them which means there's a light on the dash. I thought this would be a simple fix but can I find one???!!! (Probably why he fitted a different one). Parts supply for the car is good but as this is not a common part that needs replacing noone stocks it, even new master cylinders which are easy to find come without the reservoir. Iv tried breakers but this is quite a rare car now (when did you last see one on the road?) Any ideas where I could find one?
Id be very grateful for any help as I love the car and want it to be right.
Thanks guys
My Uno mk2 looks like this, not sure if the mk1 is the same?
I am restoring an early Seicento and it looks like the cap is the same
If that is the case then something like this should help you out:
http://www.ebay.co.uk/itm/fiat-seic...027700?hash=item3f320377b4:g:uTEAAOxytL9SK4dH
Is this what you were looking for? or does the mk1 have a different cap?
It looks very similar, il do some research and find out. Thankyou very much for that its very helpful
I'm based in Southport. Iv ordered one from a mk1 seicento as it looks the same in the pictures, but il see if it fits when it gets here
