im Axle Specialists
Old 28-08-2005   #1
aka Darren ;)
dazzdog's Avatar
dazzdog has donated!
Uno temperature?
hi, just bought a fiat uno 45s mk1 g reg as a runaround while the tipo is off the road and was wondering what temperature they run at because mine is always just under the red
dazzdog is offline Reply With Quote Quote
Old 28-08-2005   #2
faster! FASTER!!!
bulldog5046's Avatar
Trader Rating: 2
bulldog5046 has donated!
Re: Uno temperature?
dunno about your 45 but on my ie start its always in the middle about 100 i guess... doesnt say tho. mine start at 50 and shows 130 at the top for comparison.
Ex Marea Turbo GTi-R owner & BMW Z4 3.0
bulldog5046 is offline Reply With Quote Quote
Old 28-08-2005   #3
Chris
Trader Rating: 2
Bushboy has donated!
it should sit at 90 degrees or lower (centre point on the dial).
if its going over this then the chances are that the rad fan doesnt work or the rad itself is buggered. the fan should come on between around 85-95 degrees and the car shouldnt get any hotter once its started cutting in.
if it does then somethings wrong with the rest of the system. just bellow the red is bad! get stuck in traffic and your fooked
i suggest checking the fan first. bridge the connections on the fan switch connector (the green looking thing bolted to the side of the rad). You will need to turn the ignition on for this aswell. but when you bridge the connectors, the fan should turn on. if it doesnt, your fan is buggered.
if it does, clean out the system by running water through the rad and so on for a while to clean all the crap out, then put in a new lot of coolant and see if that helps, also poss replace the thermo and even the rad if nothing else helps.
Hi!
Bushboy is offline Reply With Quote Quote
Old 28-08-2005   #4
aka Darren ;)
dazzdog's Avatar
cheers, the cooling fan does work but it just sits below the red for some reason i will have another look at it today, cheers again
Old 28-08-2005   #5
As an emergency measure turn the heater on full heat, and the fan on full blast. You'd be surprised how much heat that will take out of the system.
My Uno 45 FIRE sits on or just above the mark all the time, but on a hot day after a longish run at full speed, with a sudden and extended slow down it will get over the mark by a fair amount, but not enough to get worrying.
pinkpunto is offline Reply With Quote Quote
Old 28-08-2005   #6
aka Darren ;)
dazzdog's Avatar
think i have sorted it now, checked the water and it was quite low so hopefully that was the cause of it
Old 29-08-2005   #7
If your cooling system is in good condition there is no reason why the temperature should ever go much past 90 degrees C. My uno overheated on several occasions and it was down to different things.
1.Connections to electric fan (as mentioned above)
2.Faulty sticking thermostat
3.Oil and water levels (with plenty of antifreeze in water)
4.Head gasket failure (probably was a consequence of the above on my car)
I hope topping up the water has fixed it for you, but if the problem recurrs you might want to investigate some of the points here. Also keep your eye on the temp as running hot is not good for the engine as it has an alloy head which tends to warp quite easily.
Best of luck
Phil
Ex 1989 Champagne Fiat Uno 45 "Breeze"
Ex 1995 Red Cinquecento Sporting
2000 Mercedes A160 Avantgarde
phil_harry is offline Reply With Quote Quote
Old 30-08-2005   #8
aka Darren ;)
dazzdog's Avatar
nice one phil, thanks alot
(G) Fiat Uno, Engine temperature problems pikkumies Uno 6 17-11-2016 15:48
(G) What age Uno do you drive? Mk1 or Mk2? Chas Uno Uno 42 20-12-2007 18:59
(G) New Uno Moderator + Uno section Upgrade!!! Louie Bee Uno 19 31-03-2005 17:04
(G) UNO 1108 i.e. temperature sensors andre79ge Uno 2 18-10-2004 12:12
(G) UNO 999 cc temperature question Sreenath B.H Uno 4 08-04-2004 20:16
