Hei.
I have some strange clonks from the front somewhere. The clonk has been there for a while, and I have done several investigations under there.
Best example is if you imagine a manhole cover in the road. The cover is 2 inches lower than the asphalt surface. If I drive straight over it there is a little clonk, but if the manhole is in a right curve, I turn the steering wheel to the right (ofcourse), and drive over it with my LEFT front wheel there is a much harder CLONK.
The same thing happens if there is a left curve as well, but not has hard as when I do a right curve. I then drive over it with my RIGHT wheel.
Shocks are 3 years old. Springs are 2 years old. Upper "shock bearing" sets are 2 years old. The main wheel bearings are 2 years old.
What could be the problem? The bushes seems fine on both trailing arms (right part?) and on the anti-roll bar (fitted last year). Can´t wiggle any suspension parts - evrything seems tight. Are the shocks shot? How much play should there be on the engine mount on the beam under the car?
The tracking is still working fine, and the steering is good (except it has 4 turns, and not 3 - 3&1/2)
Any suggestions greatly appreciated.
Morten.
Morten.
