Thomas P
Can anyone help, please......................I have a 1995 Uno diesel. For the second time now the windscreen wiper motor is going intermittent - the problem begins with a momentary stop mid sweep and becomes progressively less intermittent until the wiper doesn't sweep at all and then for no apparent reason after a few moments the wiper will work again but eventually the problem becomes so bad the wiper just doesn't work anymore. I have had this exact problem before which was cured by replacing the wiper motor thereby eliminating the wiring or switch from causing the problem. The question is does anyone know what exactly causes theis problem and is there a sneaky repair that one can do to the motor unit?
Any comments gratefully received
thanks in advance etc
Thomas
Thomas
