.I wonder if Jo0lz replaced the bolts on the X1/9's engine when he went through all those head gaskets. That's a different engine
anyway and more stressed than the little FIRE in the Uno
YuP I used new bolts
Problem in the end was the head was pin-holed somewhere
Or possibily fractured
Ultimately I knew I had personally DuFFeD it
By putting a load of stone cold water into the engine when it was hot enough to be burning the oil off the outside of the block from a known oil leak
The thermal SHoCK did that alloy head no good whatsoever
If you have a replacement engine exactly the same it would take half a day to swap them over
I only needed a engine crane because I left my gearbox insitu
and it was pretty darn near impossible to balance the engine on a trolley jack and waggle the gearbox into the right location for the input shaft to go straight into the clutch ALL ON MY OWN
In the end I hired an engine crane from the hire shop round the corner from my house at 9am, took it back at 11am that same morning as by then I'd done the engine transplant
So you looking for some help..........
