happypaul
MK1 Uno 45s Fire 1ltr Refusing to start! - coil squeeling!? wtf!
Right,
Mother Fiat Uno 45s with the 1ltr fire engine will not start.
Only problem weve had with this little minter is when the manifold cracked when I changed the exhaust on it! so had to use a later punto manifold and modify a downpipe to fit!
Anyways,
She drove it as always, 10 mile journey, turned it off, 10 minutes later went back to it, would not start.
The starter turns over, and its getting fuel.
When I got chance to have a look at it, when I turned the key it was as normal but it was turning over and over, tried to have a little go every now and then!
Went to get some tools to take the plugs out (which I couldnt find anyway)
So checked all wires.
Had another go, and I heard a squeeling noise!
Coming from that thing bolted on the N/S inner suspension turret, with its wires going in and out of it. Realised it was the ignition coil.
After this, it didnt squeel. But the engine would just turn and turn and wouldnt even try have a little go into life like it was doing before the squeeling happened.
I take it this would mean that the coil is nackered and I need a replacement? Seen one for £15 brand new which didnt seem too bad.
I just find this very strange, although I suppose as it is a 1987 Fiat, with 67k on clocks it is getting on a bit so things will just break.
Any other ideas on non starting if that wasnt the issue? (even tho surely its got to be down to that??)
Also, could somebody please tell me which colours go to which point on the coil itself, just to make sure I dont put them on the wrong ones and naff up a new one.
Any help / ideas would be greatful as I'm not used to these pretty "simple" ignition systems as I'm more used to EFI and the odd old diesel! :yuck:
Cheers, Paul.
Right,
Anyways,
Cheers, Paul.
