Old 26-07-2004   #1
uno electrical problems
hi can anyone help i have a fiat uno 1100cc MK2 91J with a intermitant electrical fault that i am beating my head against brick wall i dont really know much about car electronics,problem is when car reaches normal running temp all the electrics cut out temp gauge goes off the scale radio cuts out head lights indicators engine cooling fan interior light when doors are left shut key out of ignition hand brake light glows then it can just return to normal then it may do it again, i have replaced fuse box and checked connection blocks etc.what do i do next?
andy is offline Reply With Quote Quote
Old 26-07-2004   #2
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
have you checked the bodywork earth connections, including the engine to body earth straps?
A Dog Is Not Just For Christmas
Sliced Thinly It Can Last Till Easter
Old 27-07-2004   #3
Chas Uno has donated!
Air Dodge Champion, Asteroids2000 Champion, Frogger Champion
Could also be a faulty ignition switch. These can wear and give similar faults to those like you are experiencing. The contacts inside the switch, by that I mean the electric switch that bolts onto the ignition key barrel, can give intermittant connections and give similar symptons. Other than that, check the battery cables and the engine/ gearbox earth leads.
Chas Uno is offline Reply With Quote Quote
Old 30-07-2004   #4
NobodyBlamesTheHappyGuy!
Morty Mort's Avatar
Trader Rating: 2
Morty Mort has donated!
Norway
When the car reaches 100 C the fan will cut in. It may be a fault here. Try to start the car and let it idle until the fan starts. If your car goes berzerk at this point, it may be it. Anyway it sounds like a good old Fiat earth problem. We had one on our Ritmo Abarth. There was an earth block with many wires attached, and it was rattling on the bodywork. Instruments etc. went crazy.
Morten.
gas lowered on abarth wheels. upgraded interior and visuals. audio through phoenix gold and kenwood. air through k&n.
projects: exhaust. rust removal.
Honey that ain't no pistol - that's my LOVE GUN.
Morty Mort is offline Reply With Quote Quote
Old 11-08-2004   #5
Re: uno electrical problems
Ay up mate i had this happen to my old uno,it is the earth cable that goes from battery to the block or where ever,half way along its length it has the outer casing removed and is squashed into a crappy earth connection with loads of spades coming off it,chop all the old spades off and renew and clean big conector and grease it then clean main lead flux it and solder to old tag with heat gun and also run an earth lead back to battery for good measure.
Cheers paul
paul w is offline Reply With Quote Quote
Old 10-12-2014   #6
Portugal
I know it's been 10 years since this topic was touched: I have the exact same problem! When the car reaches normal running temp, electrical problems start: beam lights go weaker, radio turns off and on, and the temp gauge starts responding to electrical consuming (it goes up if I turn any thing electrical on).
Did you solve your problem? How?
afonsopatrao is offline Reply With Quote Quote
Old 18-02-2015   #7
South Africa
check your earth cable under the battery or and an extra earth from the negatve terminal to the body of your car
Richard Africander is offline Reply With Quote Quote
Old 26-02-2015   #8
Portugal
Thank you so much!! Problem solved!
Old 07-12-2017   #9
South Africa
Hi how did u solve ur proplem i have same issue u had with my uno 1100
Harold5881 is offline Reply With Quote Quote
(T) Electrical problems with my Tipo 1.7D (1993/4 'L') danny_bellis Tipo (Classic) 5 18-07-2004 18:48
(G) Electrical problems Splash9 Tipo (Classic) 4 16-03-2004 19:38
(T) stilo abarth electrical problems harrycat Stilo 12 17-02-2004 18:52
(T) Punto HGT Electrical Problems darren1974 Punto (Mk2/2b) 2 11-02-2004 04:05
(T) Electrical problems in rebuilding my 1.9 TD josh Tipo (Classic) 0 03-02-2003 15:41
