Hi all, I am having problems with my Uno 1100 Princess, same as Uno Fire
I could not get reverse and had to replace the selector box, now 1st is difficult to get and 2nd. How do I adjust the linkage arm to the box, it has a mechical arm with an adjustment on one side and goes to the top of the box and also the hydraulic cable, I don't know if this can be adjusted, also would like to know if an oil additive would improve this problem or can/should I rather adjust this arm for 1st gear and won't I be upseeting my reverse then?
1st gear was a bit difficult before the box was attended to
How do I know when there is enough oil in the gearbox.
Please help as soon as possible as this car is used daily.
What is the hydraulic cable for, only reverse??
Cheers:idea:
