im Axle Specialists
Old 17-06-2020   #1
jacking point
where do peole jack the front of there cars up from with a trolley jack?
the only flat strong point is quite far under the car and has the arch liner in the way?
Cal2412 is offline Reply With Quote Quote
Old 18-06-2020   #2
jim cooper has donated!
Re: jacking point
Get a big wooden block (say 4x4) and cut a groove in it so that the flange on the body sill sits in it at the jacking point. Then put the trolley jack under this block. You can use it for front and rear. At least that's what I have done for years with a Stilo. Tipo has plastic shrouding with cutaways for the jacking points so the block needs to be quite short.
jim cooper is offline Reply With Quote Quote
Old 1 Week Ago   #3
chris3234 has donated!
Re: jacking point
Quote Originally Posted by jim cooper View Post
Dont use a block of wood
I'd advise getting a bag pf3-1661 jack pad from power flex made from very heavy duty rubber and has un equal sides that very closey match the underside of the car like the factory sicsor jack
chris3234 is offline Reply With Quote Quote
Old 1 Week Ago   #4
Re: jacking point
Yes, this is a better idea. My wooden block never split but I was perhaps lucky.
Old 1 Week Ago   #5
Re: jacking point
Vag pf3 1661
That should be dam auto correct
(T) Jacking point Michael1973 Punto (Mk2/2b) 3 28-08-2014 06:32
(T) Jacking point Pete145 500 (Classic) 2 24-06-2014 20:07
(T) Jacking Point? Stuart_89 Stilo 5 02-09-2010 09:21
(G) Jacking Point? Wozza1985 Punto (Mk2/2b) 2 28-01-2009 18:47
(G) Jacking point minimad99 Stilo 3 24-08-2006 10:04
