Get a big wooden block (say 4x4) and cut a groove in it so that the flange on the body sill sits in it at the jacking point. Then put the trolley jack under this block. You can use it for front and rear. At least that's what I have done for years with a Stilo. Tipo has plastic shrouding with cutaways for the jacking points so the block needs to be quite short.
