NaH!you do know that you will need to invest in a gallon of T-Cut
So long as it is taxed and insured and there is nothing totally illegal, such as bald tyres, [instant point on license] I wouldn't worry too much for the journey home.That, is a damn good plan Joolz, and one I had not thought of.
I had the idea of replacing my known knackered dizzy with the one on the car now, then ringing the RAC and having them tow me all the way home to Wales.
Hopefully going to get it tomorrow.
I reckon as long as I get it booked in for an MOT, with written confirmation, that if I do get pulled over by the police for no MOT, I can argue that I am taking it to my local MOT station for a test on Monday.
As long as I have insurance for it, it should all be ok.
Now, to start the list of little things that I need to do to it![]()
DON'T "reddex" itWill nab some reddex and fully top her up with fuel, check oil, water level, washer fluid and tyre treads and pressures before I set off too.
Hmm FucT.FiaT does a similar thing....it doesn't run HoT...AND with the big NEW HOLE in the front bumper it actually runs CooLThere does seem to be a problem with the cooling system though - the car isn't overheating by any means, but the coolant level has significantly dropped after the long drive I just did - it's not leaking out of the cooling system, but instead the heat of the water is causing a pressure build up, which is causing the safety valve to release, spraying the bonnet, battery, and some of the engine bay with coolant. Will refill and bleed it before I set off on the next long leg of the journey (entire length of the M4) and see if it makes a difference.
Ohhhhhhhhhh LEAVe it with that NATURAL patina.... . . . well for a few weeks at least....Paintwork will definately buff up to a nice shine.
Congratulations Ucof!
Hope it turns out to be as good as it sounds
Saying that, you do know that you will need to invest in a gallon of T-Cut and remember that buying Unos is addictive. Soon you'll find yourself buying more and you'll end up with three like me, or two like Jai and enough spares to build at least three others![]()
Don't worry about it though, just flush it through and the water will run clear after a day or 3. My turbo took ages to clear, but the engine had been stood empty for who knows how long, and I'd already washed out all the pipes and heater matrix / rad before I put it all in. just keep filling, funning for a bit (till stat opens) and empty repeat with fresh water.
When the water runs clear, do it again for good measure then (and only then) add antifreeze 50 50 mix.
GOOD CALL . .. ...coolant may be passing the rad cap cos the rad cap needs replacingthat seal don't last for ever ya know
