Hi everyone,
I have read quite a few threads on the forum about the "Engine Failure" message on Stilos, but can anyone help with my situation? I have the 03 Stilo 16V aircon model. A few weeks ago I turned the ignition and the car stalled, with the error message "Engine Failure". If I started the engine again and gave it some more revs for about 30 seconds, the car was driveable. Took it to my local mechanic who plugged in the OBDII diagnostic tool and it came up with manifold (something beginning with A - sorry cant remember) pressure sensor error - or MAP sensor. Got this replaced (I think it was a a non fiat replacement) and car drove great for a week. Went to start car up this morning and same thing happened - stalled on starting, same error message, needs more revs to get car driveable after 30 seconds or so. just taken it back to mechanic who plugged OBD in again - comes up with same MAP sensor error!. He says he will replace it free of charge as it might have been a duff sensor? Is this common do you know? Is it likely to be a duff sensor or is something else likely to be at the root cause of all this? I've noticed recently that when the car idles, the engine noise seems to change pitch from high to low - not really noisy or anything but a definate change in pitch - could this also be related in some way? Would appreciate any thoughts/suggestions.:worship:
