Technical Yaw rate sensor / lateral acceleration location
Omarico
hello ! please any help is appreciated.
okay so i own a bravo 198 T-JET 2007. i have a code on my ASR which is the yaw rate sensor. i have just removed the WHOLE CENTER CONSOLE searching for it :bang: :bang: . i desperately need to find it so that i can fix it or replace it. so does anybody know where to find it ???
Item 3 in the diagram below. It's only fitted to vehicles with full VDC (Vehicle Dynamic Control) also known as Traction Control.
They are usually fitted on the top of the centre tunnel. but it looks like it may be under the left front seat.,
Yes i have full VDC by which the ASR OFF button confirms that. But why does the eLearn software pinpoint it under the climate control ? That's where i was digging the whole time. Just behind the stick shift.
The picture with the 2 screws is what eLearn lead me to ( sorry it's upside down, if you open it it'll be upright ). The second one shows which place i was talking about but on the passenger side.
Anyways i'll search for it again under the driver's seat as you told me.
Thanks !!
Already took off this whole panel and searched for it there. Nothing. Please see my pictures you'll find that i was already looking there.
Thanks anyways !
Here. Sorry it's out of focus.
I looked under the seat and even removed the carpet.
I only found the connector for the seat AIRBAG and what looks like a weight sensor.
The other one is a relay. Searched for the part number online and it turned out to be a relay.
Diagram from the Fiat dealer workshop manual suggests the Yaw Sensor is behind the gear lever or handbrake lever.
This is what elearn say
