Technical X290 Ducato replacing classic lights DRL
Holandsko
Hello,I need help on how to proceed when changing the front lights,I changed from classic to lights with LED daytime running lights,but they start flashing after starting
I can connect to the ECU with MES,I read that something needs to be changed in the proxy,but I don't know how to proceed
Thank you
Ducato x290
3.0 130kw
2017
Ive not done this myself but think the best approach would be to backup the proxi file which should still work with the original configeration if you were to refit. Then run the new proxi alignment.
Sám som to neurobil, ale myslím si, že najlepším prístupom by bolo zálohovanie súboru proxi, ktorý by mal stále fungovať s pôvodnou konfiguráciou, ak by ste ho znova namontovali. Potom spustite nové proxi zarovnanie.
dakujem tento postup som skusal 2x a bez uspechu, jedine co som cital je ze treba zmenit 2 byte v proxy ale neviem ako
thank you, I tried this procedure twice and without success, the only thing I read is that you need to change 2 bytes in the proxy, but I don't know how
If you use the same procedure as backing up the proxi file ie use a text editor like notepad or notepad++ then change as per your instructions.
So,I have successfully connected the lights, in the proxy you need to change the bytes at position 76 to A8 and the bytes at position 134 to A0,if anyone has a similar problem after changing the lights to lights with LED daytime running lights
Thank you🙂💪🫶
