Technical X250 Odometer issue?
NWPT
Hi Guys,
Got a strange fault with my 57 plate 2.3mjet. After around 20 mins of driving the ABS and brake warning lights appear on the dash, the odo and trip to then not click up, so effectively I am not clocking up any miles. I have had Bosch KTS on the van and it says speed signal not complete, the speedo works fully. I am pressuming the speed is taken from the gearbox and the odo from the wheels. The fault is intermitant and I think is being caused by heat?
Anyone had or heard of this before?
I am pressuming its not a sensor issue as they either work or don't, could it be a relay overheating?
I had a problem with my speedo not working, and read on here that the speedo finds its pulse from the ABS ECU. I removed the main loom plugs from the top of the ECU to find one had moisture in it.
Stu
