writing code
writing code
Savage
Royal leamington spa, mid
IS there anyone here who is good at writing code who could help me out i am in real need of it its getting close to my deadline of end of work today and this is the last bit i need to do
i am using VB i am trying to put the code in infopath to allow wildcard searchs. i have the code, the database and infopath file available if you need it
in future if you want help just post the crap up and explain exactly what help you need. its better than asking for help and then people having to ask you to let them help.
infopath is just xml forms that use SQL queries. usually you need to make ADO's (ActiveX Data Objects) to display the results of your query, and you need to write the SQL query yourself.
there is a nice MS support document that should do what you want.
http://support.microsoft.com/kb/826992
thats the document i have but i am clueless with coding and changing code i was hoping someone could tell me which bits i need to change if i could show them a copy of the work i was doing
i will try and attach the documents aswell later tonight
