Technical  Wobbly steering wheel at high speeds
cmosfxx
Established member
Alright guys... Let me first list the known problems the car has right now.
(the car is LHD)
1) Spring noise when steering at low speeds from the left somewhere - although the actual spring is not vibrating. I guess it's a classic top mount problem. Some days I hear it, some days it's fine. :bang:
2) Right drop link got stuck a year ago for unknown reasons and the small boot teared apart completely.
3) I think the stabilizer bar needs new bushings. Loud noises (non-metallic) when it's hot over potholes. (No noise over bumps etc)
4) Engine mounts are soft. Engine is shaking a lot at low speeds/gears.
5) Rear shocks have 25% difference in performance (L/R)
Now, the steering wheel is wobbly (shaking left and right) at high speeds ~70 to 100mph and ONLY on acceleration.
Less than ~70mph or more than 100mph and it's fine.
Also no shaking on WOT low speeds.
If I let the gas out it's stable again, no shaking etc.
I've replaced tyres (brand new dunlops), balanced wheels, switched wheels front to back etc... No difference. :bang:
Any ideas on what to look at next or what it may be? Mounts, CV joints, suspensions (a lot of miles on them)
Sounds like CV joints, Normally the inner. I see you found this post
https://www.fiatforum.com/grande-punto/454969-shaking-vibration-front-wheels-60-80-km-h-2.html
Seems to affect the tripod / tulip syle inboard joints.
The Croma suffers from this and got a lot of bad press as a result, but we have a easy cure and upgrade which is to fit Vectra C drive shafts. These have ball type joints at both ends and effect a complete cure. As a bonus second hand Vectra shafts are cheap.
Unfortunatly this is not an option for the Punto.
Robert G8RPI.
Robert G8RPI.
Should I replace both of them or just the right one?
I'd check for radial play (up-down-front-back) before taking the decision ...
BRs, Bernie
If someone here helped You fix -or better, understand- your issue, hit the thanks icon @ bottom right corner, it's free and makes us feel helpy ;-)
BRs, Bernie
Axle is solid, no play at any direction... I haven't tried to play with the cup. I'll check it soon.
Just an update, I've found a stripped wheel bolt. Hub is damaged.
Perfect.
Bad news, was the Wheel kinda loose or still stiff on the 3 other bolts ?
If you want to restore your hub, Google for M12 x 1.5 helicoil, that's what you need ...
BRs, Bernie
BRs, Bernie
I think somebody installed 12x1.25 bolt on my last service. Anyway....:bang:
I know about the helicoil / timesert solution but I'm going to replace the bearing and the hub.
The four of them !? Must have been pretty obvious something was wrong no ?
Anyway, I wouldn't rely on a 4 helicoiled hub neither; safety first ...
BRs, Bernie
BRs, Bernie
Oh no only one bolt was wrong. I don't trust helicoils on hubs tbh :eek:
Quick update
I've replaced all discs, fixed the hub and the anti roll bar bushings. No difference.
THEN I re-balanced the wheels and the steering wheel is now stable at high speed accelerations.
Multi-reasons issue; the hardest to solve but you did it... Congrats !!
BRs, Bernie
BTW, thanks for the sharing !
