Wiring Kit advice please..
peterp
United Kingdom.
Hi all
Looks like I might have a go intalling my sub & amp in my boot.
Could someone please advise me on the complete kit I'll need to make the install-everything included please.
My set up is a 200w 10" enclosed sub run from a 240 x 2 ch amp,Sony HU 55 x 4 .I also have 6x9's installed but not too bothered about those.
Will the full kit include the correct inline fuse/holder..?
Thanks for your help
Peter
activematt said:
You can buy kits from people like Autoleads that give you all the wiring you need including the main power lead with inline fuse, i believe they come in different power ratings depending how much power your planning on putting through it.
Yes Autoleads do just about every bit of kit you'd ever need for your install :)
Also you are correct, the more watts you want to run through, the thicker the wire needs to be.
Dont do a me and use a 600 watt wiring kit to power over 1200 watts, cos the result is smokin! :D
