Hi
Ive installed a alarm in my 1997 Bravo, and needed
to get cables through the bulkhead to inside the car. I found the easiest way was to remove the wipers and the coweling, and then on the passenger side (in the engine bay) where the bonnet hinges are, there is a small space with a rubber grommet that goes through the bulkhead, and is just above the glove compartment from inside the car, obviously the glove compartment needs removing first, i then feed the wires through, and installed the alarm put everything back together, no problems at all. Hope this helps
