Technical Wiring diagram Ducato 2.8 Diesel Kon Tiki Motorhome 2006
johncarty5
Does anyone have a wiring diagram for a 2006 Fiat Ducato 2.8 diesel kontiki vogue motorhome. I have recently fitted a towbar and electrics.
I understand to comply with the law I need to connect an audable buzzer in series with the feed wire to the direction signal flasher unit. I have the buzzer but need to know where the flasher unit is located and the colour of the feed wire to the flasher unit to make my connections.
Would appreciate any help
As far as I know the flasher is located in the centre dash behind the radio area.
The 244 workshop manual is available in the downloads section
https://www.fiatforum.com/downloads.php?do=file&id=372
it is an ISO file in a compressed rar file which can then be burnt to CD & then installed on your computer. It has the wiring diagrams for the 02-06 244 Ducato & the Fiat wiring colour codes can be found here - https://www.fiatforum.com/ducato/237319-wire-coulours.html see Fiat Wiring colours.doc
