Wiring an Amp
Wiring an Amp
N
Nick
Hey guys,
I have bought an Amp and I am wiring it right now.
However, I am finding it a bit difficult to spot a place where I can run the power cable through. Do you know of a spot which I can use?
Thanks.
think you will have to drill a hole up in the passenger side footwell.If you look on the otside take out the plastic scuttle panel trim off,you will have space ,just behind the battery pretty much..Thats where mine is.
Make sure the path is clear inside the car first ;)
i couldn't be bothered to find a hole so i ran both my power cables up the inside of the door then through the little bit of foam that goes under the front wing and out into the engine bay :)
there is a rubber bung in the passenger foot well that you can put the cable through.... just pull back the carpet and you will see it.
it's about where you feet would be, so just above where it goes flat.
mine is right up in the corner,where the ecu is mounted.Pain in *** to get to :/
C
6K
ChrisKnottIns
C
5
785
Darren
A
11
444
K
