Is there any way of recalibrating the drivers wing mirror thermometer using Multiecuscan? Mine is showing about 10 degrees less than it should.
It is 2012, 2.3 Multijet 130, Iveco engineWhat year and engine. Some use the temperature sensor as part of the regen system, others do not. The differential dpf sensor is a different sensor all together. On x250 models it is low down near the exhaust. On x290s it is higher up on the fire wall almost central.
