Technical Windows not working!?
aliandtheband
My windows, both aren't working!
This was after I removed the floors of the car, so I had to disconnect the switches, the brown for the right window and the black for the left window!
I've a 96 barchetta! and I checked in the handbook here (the 2003 one) but they say the fuse is in the engine bay near the battery, well nothing there!
I believe it's the fuse! maybe I had some kind of contact when I removed everything from the car and it did burn or something! I'm I right, or it could be something else?
What fuses should I change....is there a picture showing for what is every fuse!?
Have a look behind the panel below the steering wheel. I have the original handbook but my car was imported from Italy and therefore it is in Italian.
Steve
Please mate, under the steering wheel, there are dozen of fuses there!
It seems that in the older models there's no fuse box in the engine bay, right?
there are few fuses right next to battery, and behind eninge is big black box. there are also some fuses.... but somehow i think that fuse just for windows does not exists. could be in combination with something else. check every fuse and replace if some is broken.
check the relais (green box) under the passenger glove box.
Unplug it and refit it or just hit it slightly. I need to do sometimes...
Hiya,
Printed off a few pages from the hand book which should help with all the fuses and also the pages for the lubricants which will come in handy. (y)
The fuse for the windows is listed on page 129 as a 30A(green) fuse
