Will this head unit fit?
tomweise
Southampton
Will this head-unit...ALP-CDA9833R...(click here) work in my fiat punto mk2 with subwoofer and original speakers? will i need any extra fitting adapters other than the fascia? Cheers, Tom
The standard speakers should work as they *should*(correct me if i'm wrong cos not 100%) be wired into the ISO connector.
The sub however is a different matter. Im not sure they're wired up the same as normal amps/subs. If its connected via an RCA then you'll be fine. If its a funny connector, then you'll have to get an adapter (if they do them - again not 100%)
I think some-one once told me that the sub works off the back two speakers, and actually has no wire into the actual head-unit..as you have said..i may be wrong! lol! i think there is an ISO conector in there, and, i have a feeling that it might be the same as the one that plugs directly into the alpine unit, can anyone confirm these things for me? cheers, Tom
