Technical Will not start!
edessex
Established member
Nr. Stansted Airport.
Hi guys, I bought a 1989 Panda 4x4 a few months ago, to replace my 1991 Panda Dance which was stolen and torched (RIP).
It was used quite heavily off-road, and just about everywhere is full of mud! It was apparently a runner when I agreed to buy, but when I went to collect the guy could not get it started, but we agreed on a lower price and I still bought it.
Its been sitting down the end of my drive, as I have not had the time so far to work on it properly.
I cannot get it started. The battery is not an issue, it is dead but I jump using another car, and I have changed the starter motor. I know the replacement starter motor works, but I did not connect the leads and then try it before fitting properly. However when I put a jump lead directly onto the positive (bypassing the solinoid) nothing happens. I'm sure the engine turned over by hand when I got it (not seized).
Any suggestions to what it could be, or what I should try?
I would love to get it running and on the road!
Cheers guys.
check the earth lead, body to engine, put a decent battery on, tighten the leads to the solenoid, is the switch lead connected? check for a spark at the plugs, petrol in the tank? you say the starter works? cambelt ok? firing order right?
Cheers guys, was a bad earth. Put a jump lead from the batt neg terminal to the engine yesterday and it fired up!
It was getting dark so I didn't have the chance to look around for the earth wire, but at least I know that is the problem!
I would have tried bumping it, but the gearbox linkages are worn really bad, I wasn't even sure if it could select gears!
It looks like I have some other wireing to do in the engine bay as well!
Hopefully I will get it on the road soon! Unfortunately I have to get rid of my crashed astra (just going on ebay now), and fix my Pug 205 (as it failed its MoT) first!
