C.McMorran
I'd rather like to fit wider wheels to my 4x4, but still 13" dia. They are std 4.5j at present. Does anybody know of another fiat steel which is 5.5 or 6 that would go straight on?
Don't listen to them party poopers!
13" Punto steels are 5" and will fit. They are right about the fuel filler issue though but that depends on your tyre tyre size more than the wheels. If you stay with no more than 165/70's you'll be fine.
I believe with Mk1 Puntos that only the SX models have 5" wide wheels as standard, with the rest having 4.5".13" Punto steels are 5" and will fit.
Yep 98pcd. (Someone will chime in if I'm wrong)I don't much about pandas but if they are like any of the other fiats and alfas of the period then there will be a lot of choice. Do they have a 98pcd? If so there will be plenty of 13" wheels to go for. A set of alfasud wheels would be ideal, 98 pcd, 5.5j, 13" rim.
