General White Dash
General White Dash
yep, I know that but I would still need to take the dash out to fit them? I just want to know do you think they would look good and how hard would they be to fit? or how much would white dials cost? and how hard would they be to fit?
Unless you stick them over the glass front i would guess you'd need to take them out! :p Some good guides on Boo for doing it. Have been told the stick on ones look a bit duff.
I have white dials, which were quite easy to fit :) The only problem was getting the needles off and back on again - a lot of fiddly work there :bang: You can cut the dials to slip them over or go with the fiddling - choice is yours.
where did you get them?what were they made of?
take yours off, scan them, edit them in paintshop, print them on quality plastic, cut them out, fit them, smile.
it is important to remember that on back lit dials such as those used on the bravo, all light will come from behind the dials. this means if the dials can not let some light through you will not be able to see them in the dark.
