Hey guys,
My sunroof whistles when you go over 60mph. Iv had a look at the seal and it seems that the seal does not go all the way down on one side.
Any ideas so that I can still use the sunroof and no whistling?
You can first try with the repositioning procedure, you can find it in eLearn. I can check it for you tonight if you don't have the eLearn.
It didn't work in my case however (had similar problem three years ago), so I had to bring the car to the garage and they reassembled it. It was pretty pricey though since it takes several men to lift the roof
Lesson learned: I clean and carefully grease the rails of the thing every spring; haven't had any troubles since then.
The rails visible either side of the opening? Do you do any lubricating of the rear runners? I bought my Bravo in Jan and this hadn't been done which has resulted in the roof failing and the motor and cables had to be replaced.
Sure, here it is (button A is the one that closes the roof):
After the battery has been disconnected or a fuse has blown, the operation of the sun roof must be initialized again.
Proceed as follows:
- press button A until the roof is completely closed. Release the button;
- press button A and keep it pressed for at least 10 seconds and/or until the glass panel clicks forwards.
Release the button at this point;
- press button A within 5 seconds of this operation and keep it pressed: the glass panel will complete a full opening and closing cycle.
Only release the button at the end of this cycle.
Cheers![]()
