Which 3 bar MAP sensor - 1.9 JTD 8v
Hi mate,
Yes thats a 3bar map. Its a 4 pin as it has a temperature sensor as well, so you will need a plug for it and solder it into your loom (ignoring the temp pin as yours is a 3 pin iirc). Its not direct fit but, but I think thats the one most of the guys upgrade to when running higher boost on the 8v's iirc.
I never ran high enough boost on my JTD to need the MAP upgrade, so haven't personally done it. But thats my understanding anyway.
hope that helps,
Alan
In case its any use...
Bosch 0281002437
You have to calibrate the sensor to receive the same voltage signal for a higher boost level, so for instance if the 2.5 bar map sensor receives a 4.8v signal when the boost reaches 1.5 bar (+1 bar atmospheric) then you calibrate the new sensor to receive a 4.8v signal at 2 bar (+1 bar atmospheric)
