General Which 2000 2.8 diesel is this?
scott73
Weston
Hi scott73,
The engine in your picture has the model number 8140.43 on the camshaft cover label. That number means that it is a 2.8 idTD, which was made until 2001.
Hi scott73,
Oh that's good news, thought it was a non turbo version, how would you rate the engine? I'm used to my 2ltr Petrol engine with carbs on my old Fiat camper. Here is what the 2.8idTD is pulling ;)
The presence of the turbo may be deduced by the fact that the outlet of the air filter is going behind the engine and re-appearing as a pressure hose which runs behind the radiator. The engine has an intercooler, and has max power of 120 hp at 3600 rpm, with max torque of 210 lb ft @ 1800 rpm. This relatively low rpm for max torque makes it a good puller. It is not a racing car.
A problem on motorhomes equipped with same /similar engines and gearboxes was failure of the fifth gear, which relies on splash lubrication. OK for vans in frequent use, but after long layups gears could be dry.... I have seen and follow a recommendation to avoid engaging fifth gear for the first mile or two, particularly if vehicle has been standing idle for a long time.
Whoa room with a view , or what , huh .
Got the same engine , same year , in a left hook Hymer . Really good engine , nothing to go wrong . Actually despite only 122bhp , pulling 3.7 ton (i've replated) , i surprised at just how grunty it is , returning 32 mpg into the bargain .
Mechanical parts still relatively easy to source , but trim is virtually non existent , not really an issue with a custom vehicle . Can't fault it .
