johnson550 Fiats since 1973 Parked in the garage Joined May 15, 2006 Messages 1,362 Points 336 Location North East Jul 5, 2008 #1 Can anyone tell me the diagnostic machine plugs in at?
bandido41 Bandido A Maneira!! Parked in the garage Joined Feb 15, 2007 Messages 2,045 Points 346 Location johannesburg Jul 5, 2008 #2 If its the same as the bravo's (which it should be ) then you have to remove the glove box and it should be behind there.
OP OP johnson550 Fiats since 1973 Parked in the garage Joined May 15, 2006 Messages 1,362 Points 336 Location North East Jul 5, 2008 #3 bandido41 said: If its the same as the bravo's (which it should be ) then you have to remove the glove box and it should be behind there. Click to expand... Do you mean all of the box not just the inside bit
jug blessed are the apostates Parked in the garage Joined Nov 28, 2005 Messages 27,935 Points 3,853 Location Durham Jul 8, 2008 #4 on a 2001 diesel model you should have the 16pin connector behind the fusebox cover (in front of driver's right knee)
OP OP johnson550 Fiats since 1973 Parked in the garage Joined May 15, 2006 Messages 1,362 Points 336 Location North East Jul 8, 2008 #5 youre right once again Jug
