Technical Where to get -Headlamp for 2021 model with daylight running lights
VXman
Milton Keynes
The best I can find on ebay is £527. Anyone got any suggestions of cheaper suppliers.
Drivers side, black, part number 1394424080
Model
Fiat ducato
About half that price at Coastal Motorhomes I believe, if you buy the bare lamp unit without the LED driver. Just have to swap the driver over from your old lamp to the new one, unless it's your LED driver that's packed up. It seems that the RH lamp is out of stock at the moment, but CM may be able to give you some idea of a restocking time.
There seems to be a big variety in part numbers. Does anyone know the difference between 1394424080 and 1394425080
rhd vs lhd perhaps
With modern day headlights, just buy the exact same part number as the original you're replacing.
Part numbers can also change when a component is revised or obtained from an alternative supplier. A revision would mean that the part is a replacement for the original which is no longer available other than from unsold stock. Coastal Motorhomes would probably be able to answer as I believe they have access to the current Fiat parts catalogue. Alternatively you could try a Fiat dealer but you may find them less helpful.
