General  Where is the ECU?
blabummu
Stourport
HI. After much expense and time wasting with Halfordsx Im told the ECU on my car is at fault. Fiat want and arm and a leg to fix/replace but have come across ECU Doctor who seems legit and reasonable cost wise.
Problem is I dont know where the ECU is located on the car.
Any help/thoughts?
FIAT 500X 2016 1.4 MULTIAIR PETROL
In the engine compartment centrally located on rear bulkhead below the screen. Has a big fat cable either side and probably a yellow strip on each of the plugs.
You don't say what the fault is, or error codes etc. Are you / they sure it is the ECU at fault and not something else, e.g. bad earth connection?
