Technical where do these 2 parts go
sprie
rye
I have got the motorhome ready for MOT on Tuesday - fingers crossed for that.
I did notice some power steering fluid under the van today, but i can't see any sign of leaks when i look underneath. I have a forlorn hope that the seals were dry from no use for a year, and now that the power steering system has been refilled etc, the seals are now working and my leak might magically disappear. Is that nonsense? I did trying turning the wheel from lock to lock with the van not moving, to put the system under pressure, but i can't see any leak at the moment.
Anyway...
I have 2 parts left over from the rebuild: the one on the right is the more significant one - does anyone know where that goes?
The one on the left looks like it holds hoses, and i probably have various cable ties doing the same job, but if anyone recognised where it goes, that would help?
If you add 2 photos with one piece per photo, you could be able to use google lens or other reverse image browser plugins to get some help from the internet ;)
Then you have ePER - which is the FIAT spare part catalogue. You can find the link on the bottom of the forum banner, the search window is top left of the screen. However it would take hours to get through all of the diagrams. But if you have an indication where they might come from, it should be easier.
Search with the VIN of your vehicle - ePER will by default display only parts for your model, which will limit the number of diagrams to check.
hi. i have now tried google lens, but it didn't come up with anything. I have no idea which area of the engine it comes from. as you say, it would take a long time poring over the diagrams (i do use the parts diagrams to help me with other parts).
atb
atb
Pity. Aren't there any numbers on the pieces? I can see the beginning on the smaller one.
Normally the producers put numbers that help to identify the parts.
Not a perfect match, but that bracket 2 looks similar:
That's what I saw earlier , but these diagrams are usually spot on so I thought better of it.
I would jave thought (for the other part - on the left) is to find the two pipes that run close together , offer it up all along those two pipe's run.
The part on the right certainly looks like it is fitted around a circular 'device', like the pump
