Wheels
Wheels
dagod
I've a question... I found some really nice momo tuner wheels but they were on a 2001 Seat Ibiza... so 4x100 16' 7.5 and the ET is 70mm?!?!? So here's the question: Does they fit on my bravo? And what I need?
thank you
no
et is to much
Smee
thak you!
But what's the Bravo ET? 37 millimeters? what's the limit for it? thank you
pcd 4 98 or 4 100 with wobbly bolts
offset 30 - 38
center bore 58
Smee
if its the center bore u will have to buy some spigot rings to reduce the size of the centerbore. mine on my car are vauxhall alloys
Smee
ok I've all the info now:
the wheels (Momo Tuner) was originally on a Seat Ibiza (2001)
4x100
7,5Jx16H2
ET35
Center Bore 72.2 / 57.1
on the wheels there are some texts:
1) POD100 ET35 TBX L10
2) typ 314 M18 278 mr
So: does they fit smee (or any1else)?
ERR. lol pass sorry chap how can it have to center bore numbers
Smee
Smee, keep up the good work :)
The Bravo CB is 58.0. You can only use spigot rings to make CBs smaller, not bigger.
Most aftermarket alloys can be fitted with different rings to suit different cars.
right the 72.2 is the maximum size bore! so you need to contact the wheel manufacturer tell them the model of the wheel and what bore size you need the spigot rings to be then they will send them to you (i know tsw send them out for free!)
to fit them get a hammer and a screwdriver and knock the old ones out of the wheels from the front side. turn the wheel over on a soft surface and bang in then new ones.
so can i say surely that they'll fit with spiggot rings and wobble bolts?!?!?! I'll call momo before buy! ;)
R
342
RascaL
R
R
786
R
J
6
544
jords
J
5
578
Robin
R
