Hi folks,
The Pandasaurus has recently developed a whirring noise from the front right wheel.
I'm 99% sure that's what it is, but before I spend the cash, can anyone check my reasoning quickly?
So...
- Speed dependent whirring noise (not grinding or whistling)
- Present when going straight or turning right
- Doesn't change with gear selection or when coasting
- Stops if I turn right / brake
- Swapped tyres around and it's still there in the same place
- Unsure if there's movement in the hub (the strut has a bit of wear in it - planning to replace next week. The wheel moves a bit, but I'm not sure if it's the strut or the bearing - probably both
...so I'm thinking it is the bearing. The fact that the changing load shuts it up seems to make sense with that. It doesn't clunk / do anything funny at low speeds which might be expected of a CV joint?
Keen to get it fixed ASAP - I read on the forum a few mentions of chocolate wheel bearings etc. - any recommended brands? Haven't come across any from the usual suspects (SKF, Timken etc.) - just pseudo brands on eBay. Will I be doing it again in 6 weeks if I fit this one fr'instance?
http://www.ebay.co.uk/itm/FRONT-WHEEL-BEARING-KIT-LANCIA-SEAT-FIAT-8210-/371150731656?pt=LH_DefaultDomain_3&fits=Model%3APanda&hash=item566a4eb988
So...
