Technical wheel alignment studs
get a tin of plusgas and a BLOTORCH!! soak the studs in plusgas and leave for a few minutes when they have soaked up the fluid apply more then use the torch to heat the studs,once you are confident that they may come undone use the correct sized ring spanner and try gently freeing them off but dont force them or they will snap, If they wont come free keep using the plusgas and the torch, its a case of trial and error, I have used this method hundreds of times over the years on many a rustbucket and believe me it works!!
