Hi i was online browsing through pictures of Uno's When i saw this picture:
Number 1: I This a good place to place the cone filter??
Number 2: Whats that small red thing to the bottom left of the cone filter? I left that pipe exposed when i attached my cone filter.
Where is the best place to place the cone filter? i have 1 meter of flexible tubing so i can place it anywhere. And can i get one of those from any spares shop?
As far away from the engine as possible and where the air is likely to be coolest. That's why most modern cars have air intakes behind the headlights so you could do the same for yours
However, you have a carburettor Uno so if you run it in cold and damp conditions i.e. below approx. 6 degrees you'll be at risk of carburettor icing. That's why the airbox has a thermostatic flap and a hot air pipe coming from the exhaust manifold
I know the pick is a bit small but save it and zoom in,,,
A freshly build Uno Mia motor with the same air box but the filter removed and a cone filter and induction pipe fitted to the air box
