T
Tom
Ahh... lots of info you failed to mention
nicos car isn't lacking power. Infact I think he has too much now
Peak power on a 155HGT is under 6k, but 80 at the wheels is rather low.
Engines can missfire when cold cos they are cold. Simple as that. The combustion process doesn't work as well when its cold, the compression is usually lower as all the metal parts have not expanded to the right size, spark plugs don't spark as well, valves don't quite seat right, the oil is VERY thick and causes drag, lots of fuel has to be added to make it run and this can foul plugs making them stop sparking for a few revolutions etc etc etc..
Engines like to run at ~85-88degC, not 10degC.
When you add cams with longer duration and longer overlap the problems are compounded at cold idle as the compression will be even lower.
