Hello all.
My Fiat 500 1.2 petrol manual is in bits on my driveway. Bought it with a lot of damage for next to nothing as a project.
The subframe is off to replace the gearbox and I’ve also replaced the clutch. Now, after I’ve refitted the gearbox, I can turn the hub with the car in gear, but as it turns, the engine doesn’t turn with it. The other hub does turn so in my head that says the gearbox is operating correctly. As the car is in gear, I would have expected the engine to turn as I turn the hub.
The gearbox was a right pain to locate back in position, so before I take it off again, is there something obvious I could be missing?
I’m pretty positive I fitted the clutch plate the correct way round as I remember double checking. I can also see the gear linkages move as I change gears.
Annoyingly I can’t simply start the car and see if I have drive as it also has an electrical problem at the moment I also need to fix (I love me a project).
Any suggestions would be helpful. All I can think of is I actually did put the clutch plate in the wrong way round even though I’m positive I didn’t.
Also hints and tips for easily handling and locating the gearbox when the car is on axel stands would also be welcome.
Thanks in advance.
Thanks in advance.
