Looks like a standard IC ,,, Cd4001cn mm5601anCould be anything...
Can you retype the numbers on the chip? Perhaps that would show some results on the internet.
I guess emissions maybe? I plan on tracing at some point - the wiring goes up behind the glove box along that lower support rail (behind the dash).Looks like a latching timer, designed to turn something off after a preset time. Wires are quite chunky, so perhaps a mirror/or rear screen heating circuit. (having a stab in the dark here) so does your vehicle have any of these? Are you able to trace the wires?
Wiper timer is a SOLID suggestion. I think you may be on to something there!!! I am going to test this out when I get home this evening!...It could perhaps be a timer for the intermittant setting on the wipers?
Can I ask what makes you think emmissions?
It's a NOR gate:Cd4001cn
This was what I noticed as well, made me wonder if I was an immobiliser of sorts or something that turns on a light when either door is open? Looks like the package has two NOR gates. It’s pretty basic logic, so I have to wonder if it’s a “module” of sorts for a dash function. Maybe a chime for leaving a door open or not putting on a seatbelt.It's a NOR gate:
A NOR gate delivers a high output only when neither of its inputs receives a high signal. In simpler terms, it provides a false output if any or both inputs are true. This behavior makes NOR gates fundamental in constructing logical circuits and forming the basis for more complex operations.
Doesn't sound to me like wiper timer. But I can be mistaken, it's too late for me for such logical thinking![]()
Could also be something like that. But the wires look thick for such usage.This was what I noticed as well, made me wonder if I was an immobiliser of sorts or something that turns on a light when either door is open? Looks like the package has two NOR gates. It’s pretty basic logic, so I have to wonder if it’s a “module” of sorts for a dash function. Maybe a chime for leaving a door open or not putting on a seatbelt.
I thought that myself, but then remembered back in the 70s they would use 40 amp wire for everything.Could also be something like that. But the wires look thick for such usage.
Are you interested in getting a photo of the other side of the circuit board? That would make the circuit function easier to work out. As mentioned previously, its a pretty simple circuit, so I'm sure between us all, we can work it out. (Maybe)
I did spot an extra red wire hidden away... would love to know what's on the end of the white wires.
There is a red wire in there somewhere, you can see it coming out of the top of the bundle in the first picI'd say the red spot is not a wire, but the color of the middle of the three vertical elements in the center, from which the 1st from the right is definitely a resistor.
Ha, you are probably right. I was looking at the PCBThere is a red wire in there somewhere, you can see it coming out of the top of the bundle in the first pic
