bigbilly69
I have a campervan based on a Fiat Ducato chassis but cannot find agreement on what engine oil to use in it. It is a 2017, 2.3 Multijet 2 150 (NOT stop and start !). Any help would be appreciated. Many thanks. Bill
So just the wrong grade, the wrong ACEA rating and not to the required Fiat specification then. Seriously, why would you risk doing that to save a few quid?I'm using Tesco 5w/40 C3
Before I cause you any anxiety let me say right away that I think it very unlikely that using this oil viscosity 5w-40 instead of the recommended 0w-30 in our relatively mild climate conditions is most unlikely to have any detrimental effect on the engine and ACEA C3 is a very modern spec of low ash (so it protects DPFs etc). Here is some "serious" reading all about the ACEA specs if you want to delve deeper - the top quarter of the "page" is probably all you need to read. https://penriteoil.com.au/knowledge-centre/Specifications/194/acea-service-classifications/364I'm using Tesco 5w/40 C3 (which I understand is made by Tetrosyl / Carlube in Bury, who supply the own brand oil to other UK supermarkets ) because I went mad when it was on offer.
I realise Fiat recommend slightly thinner oil - but presumably that has to cover very cold climates which we don't get on the UK mainland, being surrounded by water warmed by the gulf stream.
From what I have read thicker oil protects better, especially when hot. But thinner oil is necessary for extreme cold starts.
Isn't the world of marketing a mad one? There's your manufacturer discontinuing the 4 litre containers and Castrol now selling nearly everything in that 4 litre size? wonder why? Oh, silly me, they're selling the 4 litre size for around the same price as their competition sell their 5 litre bottles - Maybe they think we'll not notice?(From Jock's link above)
- C2
Stable, stay in grade oil for use in vehicles fitted with DPFs & TWCs and in high performance diesel and petrol engines requiring low friction, low viscosity and Mid SAPS (Sulphated Ash <0.8%) oils, with a minimum HT/HS viscosity of 2.9 cP.- C3
Stable, stay in grade oil for use in vehicles fitted with DPFs & TWCs and in high performance diesel and petrol engines requiring low friction, low viscosity and Mid SAPS (Sulphated Ash < 0.8%) oils, with a minimum HT/HS viscosity of 3.5 cP. These oils may also meet A3/B4* and API SN
I wouldn't use it if I thought it was harmful
But as far as I can see, the only variance from Fiat's recommendation is its slightly thicker, which is probably better for our mild climate.
And as Jock says, it doesn't mean its not to Fiat's specification
Just that they have not gone to the expense of having it tested and certified by Fiat
It says on the bottles
'Tesco 5w40 C3 Fully Synthetic Suitable for the latest high performance petrol & diesel engines including Turbo Charged. Meets or exceeds the requirements of the following specifications API SN, ACEA C3, MB229.31/229.51, BMW LL-04
Tesco Oban were selling of 4 litre bottles last year for £5 each
Why so cheap? - well apparently the 4 litre size is discontinued because
Next time I looked they had only 1 litre bottles with the same label and spec for about £10 each
Hi,Recently opened up a ducato 2.3 f1agl411d head with a broken off valve in it. Multiple rockers was worn in to the valves and the broken valves was because of this. I dont have the history of the car but it seems many hydraulic lifter oil channgels was clogged - I would in my next engine perhaps try to find an oil that would assist in preventing this? Any inputs ?
Hoping to find an answer of something like that.. "use oil x because of its soot capabilities".. or Fiat and Italian engineers should not continue to design engines..![]()
Recently bougt 2l Bottles of vw 507 for £5 reduced from 23, the better spec cheaper than the older spec. Bought for my Skoda but if some goes in my sons corsa its better than him not bothering for 3 years. Wouldnt put any thing other than correct in my Ducato every year. Thers some amazing chemistry in long life oils but only suitable for enginge that are used not Motorhomes sat doing nothing other than degrading.Isn't the world of marketing a mad one? - Maybe they think we'll not notice?
When I was at automotive college in London back in the '60's I had already, back in Edinburgh, met my future wife but not her sister. The future Mrs J came down to London to start working for an airline and moved in with her sister who already worked there and lived in London. When I was first introduced to her sister we decided to go down to one of the riverside pubs to celebrate the occasion and on the way back into town the engine of her elderly mini was running rather hot. I was by now in my 2nd year at the college so had quite a good understanding of how cars worked and offered to give the car a quick check over. There was oil showing on the dipstick, but well below the "low" mark and the rad needed topped up. The car looked generally neglected so I offered to take it in with me to the college as I'd reached the part of my course where I was in the engine shop and I knew the instructor was keen to allow students to work on "real" cars. When we pulled the sump plug only about a couple of pints of disgusting looking and very dirty oil came out. I called the instructor over because I couldn't understand how so little oil could have registered on the dip stick. "Pull the rocker cover" said he. I did and found the most disgusting black jelly thickly coating everything. - black sludge. Sister-in-law to be couldn't tell me when she'd last had it serviced! We ended up making a project out of the power unit, after removing it from the car the first thing we did was separate the gearbox from the engine (this was the "old" mini with the gearbox in the sump) and it was full of gungy black sludge which felt rather like black swarfega! This was taking up all the free space normally occupied by the oil which explains why only a couple of pints of liquid oil was enough to register on the dip stick! We stripped both engine and gearbox down to their individual component parts, cleaning everything up till it "sparkled", polished the crank journals with emery (which luckily came up quite nicely without a regrind) and fitted new shells and a set of cords "ridge dodger" rings. Many other parts were "refurbished" too, The rocker arm bushes and the rocker shaft were a bit the worse for wear but we put the old ones back because of lack of finance which was a pity because the valve gear was slightly "tappy", but it ran fine. I remember shimming the idler gear in the transfer housing especially well for some reason. It took us about a month to leisurely do all this and I put in some overtime deshiming the suspension ball joints - great fun! - and generally sorting out stuff like the brakes etc while it was in the shop anyway. Luckily the Tin Worm hadn't yet got much of a hold and the car was almost like a new vehicle when I took it back to her. I was absolutely gutted when she traded it in for a Triumph Herald just a few months later. On the other hand our instructor was absolutely delighted with the project and told us how much more we would have learned working on a road car instead of training media and it certainly did in my opinion.I was not a fan of extended service intervals either, until a friend told me he hadn't changed the oil in his own little petrol engined car for 13 years -
The car looked immaculate and was still running perfectly - But - it had only done 10,000 miles.
I read that BMW are developing an engine which, like modern gearboxes, which will be filled for life and never need an oil change.
I am not recommending it though.
I now change the oil at the manufacturers recommended intervals, wheras I used to do it sooner.
