Technical  What does Error Cli Means?
renken
Sometimes Error Cli appears in the display what does it mean?
Sadly it means Climate control error..
Does the aircon still work?
It could be as simple as a problem with the thermistor in the driver's side wing mirror that supplies the temperature to the display unit. Unfortunately I can't remember what this is, but you could check the resistance using a variable resistor to get the resitance for 25degrees C, then order the part from maplin or somewhere for a few pence, then install the new one... :bang:
or Fiat will sell you a new one for about 10 quid (which is probably easier than the above.....
saves a lot of hassle that way.... (y)
If it is not that, then it is an aircon controller issue.... :(
