Not sure if this helps, but...
Mine had a tendancy to almost stall when slowing for junctions and a slight hesitancy on acceleration. Not a major hiccup, just a slight running weak feel. The idle could occasionally dip as well.
Had the injectors refurbished, slight improvement.
Changed the fuel filter, slight improvement.
Changed the fuel pump today - bingo!
Idles better, no weak running and although it still had loads of power it probably has about 10% more now![]()
the only way I fixed the problem was with poring in redex stuff and driving for around 200km. seems like just something was clogged, I Pretty much dismantled half of the cars engine/cleaned everything, changed Idle air control valve as well, did no effect.
Only the redex helped.
Ta, I was worrying mine was idling too low.900-1000rpm when warm.
So after several weeks of no improvement, I bought a new IAC valve. Not expensive. Thought I'd solved it, went well for a few miles.. but now it really is all over the place! Perhaps need to disconnect the battery and start again.
Some progress.. The IAC valve change seemed to do nothing much for the situation. However, the temperature sensor has now been changed, plus the throttle position sensor checked and re-set. Battery disconnect for 30 mins.... and it's now "ok" on idle.
I shall be putting some decent miles on the car, and see what happens.
